Kenflo
Hello all, I have the EZ wire harness and have a question about the ignition switch. I have read many previous posts on this forum and I am a bit confused on the proper way to wire this up. I have attached a pic on how I think this should go. On the pic it shows that I will be splicing IGN1 and IGN2 on the Mopar side of the switch and connecting them to the pink coil and brown IGN wires on the EZ harness. The yellow Mopar side wire will go to starter relay. I am using a MSD 6AL so I will not be hooking any of these wires to the coil. My MSD power wire will be the pink coil positive wire coming from the EZ fuse box with a 30 amp fuse. Is this correct?
