Hey FABO this thread will show my installation on the EZ wiring harness. It has been much preparation to just getting started have read a ton of threads. Then I have carefully looked at diagrams and looked at the original harness to get hold of how all things works and goes together. Bought terminals, connectors, wire, pliers and shrink wrap maybe some more things too. Made a bracket at work to mount the fuse panel. Here we go:
It looked so bad before under the hood and the rest of the car.
I know it doesn't looks better without the spaghetti wiring but it's a later project get it nice and shiny. I did take many picture before I removed the wires for references.
Reference pictures.
Everything's out.
This is the bracket I've made. Mounted the fuse panel base to it.
Ignition switch connectors. They fit right in the GM connector that's mounted at the EZ harness.
Since the EZ harness only include power feed wire to the wipers I had to bought some wires and mounted them to the wiper connector.
Since I don't wanted to use butt connectors on the original turn signal connector I instead bought some other connectors and terminals to solve that problem.
Reference pictures.
Everything's out.
