factory and dealer air compressor differences
lildemonkid
huntersville NC
ok.... /6 dealer air 68 dodge dart i have the compressor lines, condensor, everything to put the air back on this car. but i go to put the belt on tonight and i run into an issue with my p/s pump interfering with the tensioner for the a/c belt. also the belt is hitting the timing tab over the crank pulley. am i missing a spacer somewhere? oh and im fabbing the brackets to make it work with a 4 bbl and clifford headers. :burnout:
AC cars have a different water pump pulley diameter from what I understand. Do you have the water pump pulley that went with the set up?
Was your car factory AC or do you have a dealer installed system?
car is a dealer a/c car. and the pulley is back from the w/p pulley and runs across the neck of it. plus the a/c compressor is only a single grove. if you had a 2 grove w/p puley i think it wouldnt work. the rear grove in the crank pulley is a smaller diameter and would result in 2 speeds on the w/p pulley at the same time.
Your ac inside the car doesn't have buttons on the dash, correct?
It is still only a single belt pulley but the diameter is different for an AC car.
correct. its a knee knocker. and what is the diameter of that pulley? all of the pulleys are the originals. i had just removed everything when i bought the car. now im piecing it back together.
