Factory E.F.I.
How are you going to mount the injectors? How are you going to obtain crank triggers?
The injectors and the magnum manifold will not fit an LA of any type. The intake bolt angles are different.
Can have injector bungs added to an aluminum intake. Could probably have the flywheel drilled same as the magnum flywheels for the crank pickup
