Aug 19, 2018 #1 J JDPdart Well-Known Member Joined Nov 19, 2012 Messages 50 Reaction score 17 Location MD Is there a top or bottom for factory hydraulic roller lifters? The oil drain on my lifters are on the side in-line with the pin not 90 degrees out
Aug 19, 2018 #2 360duster Well-Known Member Joined Nov 23, 2008 Messages 1,597 Reaction score 811 Location Bavaria / Germany Ha, i´ve got the same ones…...i put the bleed hole to the front of the engine, because it´s a Little bit higher in the front than in the rear….thought that was a good idea, no Trouble so far ;-) Michael
