[Found!] Factory steel wheel
Professor Fate
Push the button, Max...
Wisconsin
Tried a while back with no luck, so I'll give it one more shot:
Looking for a factory steelie, hopefully near S.E. Wisconsin. 14x4.5" rim size, big bolt circle 5x4.5. These were the base wheel on '73 and up Dusters, Darts, etc. The centers take the small diameter, later poverty caps. I already have an early B body rim of the correct size, but it takes the larger caps. Could trade, or I will buy outright. Only need one (it's for use as a spare) but would consider a pair if necessary. Doesn't have to be perfect, just straight and not too crusty.
Lemme know what you've got sitting behind the shed!
Thanks
Tim
Thanks
Tim
Hey Tim. I will check with a buddy of mine. I just bought some steel wheels on Sat. He is in Berlin, WI
I have this spare from a 73 Duster 340. I'm pretty sure I measured it & it was 14"X5.5" though, & I'm all the way over in S.E. Pa.
I appreciate it, but I was really hoping to match the size that's already on the car.
I never realized the 4.5" wide rim would be all that difficult to find, but it seems most people toss 'em for something wider.
Yeah, a lot got trashed when they were replaced with nicer looking wheels. If you needed one with the small bolt circle, I could help you out.
May be able to source. Have two Mopar contacts with at least one of them having extensive wheel rack. Southern NM location and rim conditions. No bead rots. Dave S. las Cruces NM 88012
I'll keep you in mind, shipping would be the killer. Holding out for a local, hopefully.
