mitch340Duster
70 Duster 340 Hamtramck N95. J55 code on broadcast is empty. Fender tag not available right now. Did not have hood insulation. Research indicates both could be inconclusive anyhow. SO....You peeps think this is factory or maybe dealer applied? Car is 100% original and unmolested so this would be the ONLY THING on the car that is not supposed to be there if that's the case. Car coming home from body/paint this week. I'd like to do that first if I'm going to as I'm doing as "correct' a restoration as possible, that's why I'm asking.
Product was a bear to remove, required heat, scraper and time. had a gray color to it, must have been before I power washed it or something. that is also the reason for the "lines that you see in it. Thanks in advance.
http://www.MitchAmatrudo.com/duster/duster.html
