dcam57
So put a new fan on the 360 in our 69 Dart and had a loud clicking in water pump area when running. Found this washer behind the water pump pulley. Took it out and noise went away
Comes from the same people that put washers between axle studs and drum cause drum was hitting backing plate.Looks like someone was trying to shim the pulley for proper belt alignment.
Sure wasBet that was a relief to find something so simple
