fan clutch leaking fluid,is it toast
jdsduster
indiana
73 340 duster,26" radiator.clutch is leaking the fluid(silicone) but still has resistance when spinning it.im quessing its on its way out.anyone know the hayden part# for the clutch??
Yep,time to replace it before it locks up or possibly comes loose. Try looking up your specs through Rockauto for the right #
If you are running anything but a stock engine, and on the street, do yourself a favor, and switch to a thermostatic type clutch.They are way better at controlling the water temp. And mine is well over 12 years old and still working. They are only a few dollars more, but to me, well worth it.I'm never going back.
I took my 7-blade fan and pulley down to the jobber, and found a Ford truck one that fit both, and just bolted it in with the correct spacer in a shroud.Some might chuckle at the big fan, but I'm not made of cash.I don't have lot's of loot for a rebuild if my engine cooks. My engine has accumulated more than 100,000 miles, in 15 summers.
