Fan not centered with center of radiator
Ok don't laugh too hard but I got my fan and radiator installed and the fan is not centered with the center of the radiator, is this correct. I did some measuring and the edge of fan blade is about 3 in from the outer edge of the radiator on the driver's side and about 1 3/4 on the passenger side. I currently do not a shroud but the pictures of a v8 shroud show ds wider than ps.
Sorry for all the dumb questions lately but it been almost 40 yrs since I worked on any mopars
Don't know what you have, but early A's (64) have different radiator supports for /6 and 8 cars. The 6 supports are offset to the drivers side. The sheet medal on the passenger side of the support can be cut from an 8 car and grafted into the 6 car to center the opening to use the V8 radiator. Next time you have your car slap apart.
No, early V8s ('69 and earlier) had the lower radiator fitting on the left. In 1970 and later it moved to the right.
Nope. They keep the same offset to the right. It is TIGHT on the right side. They had to move the steering box to a frame rail mount (no room for it on the K frame) and run a remote oil filter setup on the small blocks to make room for everything. Then try throwing clutch linkage in there, too...
And here I had almost forgotten what a friggin' nightmare that RH side is. :mad:
Thanks a lot!
:lol:
I just checked my 69' and the clutch is 1.5 inches from the fins and the side offset is 1/2" on the left and 2" on the right. Note: being not an AC car, you don't want a Thermal clutch, but a non thermal one so only to rotate at idle and not by the heat of the motor.
