Fan shroud: '70-'71 swap into '73?
Brad54
Can anyone tell me if a '70-'71 shroud for a 22-inch fan will swap into a '73?
Thanks,
Brad
I don't think so I tried to put a 72 in my 70 dart the off set is wrong. I will trade you if you have a nice 70 I have a nice 72 shroud. I will get pics if you are interested.
I don't have one at all, I'm just wondering how big my target is.
-Brad
I think 72 to 75 works. Assuming you have the correct radiator. They are stupid expensive and not easy to find. Good luck!
abodyjoe has it right.
Also, what is the part # that appears on the shroud? The part number can be referenced against the '71-'72 parts manual, and then you will know which cars / radiators the shroud works with.
If the shroud is for a V-8 factory car, or a V-8 car with factory A/C, each will have different applications.
If the shroud is for a 1971-72 V-8 car with A/C, or a factory 340 car, if the shroud does not fit your application, you should sell the shroud, assuming it's in very good (not broken, cracked or missing pieces) condition. I'd be interested in a 340 shroud for a factory 340 car I have without a shroud.
Look at the bottom of the shroud for a part # and go from there.
