Fan shroud bolts
Peter L
Ontario Canada
Hi guys. Installing a new fan shroud on my '69 Barracuda. It was missing when I got the car. The clips are still on the rad, but I need the correct size bolts. The threaded clips look pretty small, like maybe a #10 or 12 machine screw. Can anyone tell me the correct size thread pitch for this application?
Thanks, Pete.
I installed a repop shroud on a parts store 22" radiator this weekend and it used 3/4" #10 machine screws.
Seem to be #8, #10 were too big, would not even start. The #8 32 I had started but stopped a thread or 2 in. I did not have a #8 20? 24? to try
This is what the kit I bought says.
I don't know if the clips on my rad are OEM or not.
Clips on rad look like this.
The ones in the kit look like this
I can say one thing... Be sure the bolts are short enough, on my rad there are tubes directly under where the screws go and if they were too long they would crush / damage / pierce the tude
On my rad, there isn't enough room for the first clip type to fit between the frame and the core. Only the flat ones would work, and they have to be short or you'll end up cutting them to length.
