Fan Shroud for after market radiator
MNmoparman
Member
Minnesota
Hey guys, planning on getting some work done during spring break on the '73 dart sport. bot it with the 360 & 727 in it. does not have a stock radiator in it (i think). the square part of the radiator is 22x22 and the fan is approx 18. trying to find one on line b/c my dad is making get one to be safe. what is the best way to look or find something that will fit. i think the bolt holes on the radiator are approx 24.5 apart.
any help would be great.
Original or repro shrouds are fairly expensive ($50+, check ebay). There are also many different PN's, so confusing. That is because the exact tube locations varied year to year, and w/ engine and AC in the same year, plus the mounting holes. That is why some people have built their own using fiberglass. Look for some posts here w/ photos. Most later 80-90's Mopars you find in the junkyard have much wider shrouds. I do have an 80's New Yorker SB shroud on my 65 Newport. It fits well on my BeCool aluminum radiator since that is wide w/ side tanks.
