Fan Shroud
mrbubbles
Active Member
Clark NJ
I have a 67 barracuda 273 V8 no A/C. I have a radiator #2785973 in there now. I am not sure if this is the right one. I am looking for a shroud to go with this radiator. Does anyone have one or the correct part number of the shroud.
Any help would be appreciated
Thanks
Steve
mrbubbles66@msm.com
Ok on the radiater , the long top number varries for different core counts ( I think). The lower number is constant at 33086
On the shroud top number is 258037, lower number is 95511
Here is what I learned from experience... If you shop at a swap meet, take a tape measure with you. If buying of the net always ask the seller to measure the bolt hole spacing . You are looking for 22 inches left to right and 13 inches top to bottom.
Now you might take this info to your radiater and confirm this to be the shroud you seek. Good luck :)
I was looking for one for my 65 but no luck for an early A.
They pop up occasionally on the bay and sometimes on other forums. On one of the other lists I frequent (62 to 65 Mopars - a mainly B body but A and C Bodies are welcome as well), a guy mentioned he had a decent fan shroud he had bought for his 64 Plymouth. Said it was for a 22 inch radiator but was too small height-wise for his B radiator and the mounting holes didn't line up as well. Made him an offer ($70) which he took. Fit's any of my 65 22 inch radiators. Do believe I lucked out big time. Moral - check on the other lists you might frequent.
