Rod 69 Cuda
Active Member
Hello,
New build, '69 Barracuda, 340, no A/C. Was told the front end of motor is '70 based on right side outlet of water pump. I have a radiator that is lower right side as well. The fan wont fit as there is only a 3 inch clearance between the radiator and end of the water pump and it appears that I need at least 4.5 inches.
Q1: Does a '70 water pump stick out farther from the block (meaning closer to the radiator) than a '69, allowing more room for the fan?
Q2: Is the radiator (2582942) correct for this set up? If not, what radiator would work? Correct size and part number would be awesome?
Q3: Is the fan appropriate for this set up ('69 Barracuda, 340, with '70 front end motor, no A/C)? If not, what fan do I need? Why are the fan blades not equal distance from each other?
Q4: If this is what you had, what would you do? I kind of want to keep the water pump if possible.
Thanks and sorry for the stupid questions, haha.
Rod
Rod
