fattest cam in a 340?
any tests or visuaj inspection of timing gears, yet.
you are making something so easy, hard.
good luck
Had a factory 70 340 4sp. Valiant back in 1988, had 3.91 gears, the previous owner installed the largest Crane FT Hyd. they had, The heads had triple springs, If memory serves me, the cam had an advertised dur. of .320/.320, lift was around .570, was on a 108, It wouldn't idle below 1200 rpm, the bottom end was stock along with the heads, just had headers, single plane, 850dp, I shifted that car many times at 7800, in some cases i'd bury the tach. That was a VERY healthy cam.
