fedral thompson power steering pully
69 Bacala
Member
Need help, with pully line up, I'am using my orig federal pump 3/8" press on pully set up from my 69 Barracuda six cylinder with a/c. on a 1971 340 motor no a/c same car, Have the right brackets for the 340 butt the pully sticks out about an 1 1/2 to far. what do I need to make it work.
Mike
Any one know if you have to use the same year on all pullys for it to work.
I pulled a power steering set-up, brackets and all from a 76 Aspen and it bolted up to my 69 GTS pretty much flawlessly.
Got the right info I think. Need a pully from a 340 motor with the federal thompson pump 3/8" press on, about the same years 70 - 72 alum water pump none a/c.
ANY ONE OUT THERE HAVE ONE FOR SALE. Thanks Mike
i just changed mine out to a saginaw pump. mine was bolted to a late model magnum 360,no a/c. don't know if that will help you. call bouchillon performance,they are pretty sharpe on the pulley info.
Finally found my pictures.............
Slant Six
V8
