Feedback on World HEMI and WEDGE Short Blocks
djwhog
Anyone build one of these guys in iron or aluminum?
Looking for feedback on issues, qualitly compatability of parts etc. thanks!
There down the block from me and I can't purchase one direct, dang bastards. LOL
There 10o% compatable from what I understand. Call'em up and ask!
That's what I understand, too. I've been reseaching the aluminum block for my E-body build and from what I gather it's straight up for parts like heads, cams, mounts, etc.
So if you could do one of these with the aluminum block, what heads would be a good choice, who make a nice set of high flow low weight heads? I think when all is said and done if you go all aluminum you are close in weight to an all iron 340 right?
it would be nice to use that 4.5 bore and build 500+ inches. You would think with the correct combo 600 HP is easy on pump gas.
Anyone have a listing of parts cam etc to use for a street car running a dan with 3.54s and a 727 with maybe about 2800-3200 stall?
I would like to build one of these with dual quads, I kinda want the look and the power. I know many folks opt for the single big speed demon etc, but I would like to make it look like a 426 yet be a much stronger running beast.
I think I do reacall the alternator mount is the only real diff on the later heads, and dont these blocks allow for 440 style mounts, or if it is going in a K member in place of a 340 would you just get a schmaucher conversion mounting kit?
thanks!
Here are some specs I did come across.
FHO New Products
WP088515 World Product Aluminum Hemi Block
4.490” semi finished bore size
10.725” deck height with .600” minimum thickness
Compatible with OEM components
Provisions for external oil line when required.
Valve train oiling fed from main oil galley, not #4 cam bearing.
Provision for stock oil pickup
Standard or raised cam position available
Can be machined for 60mm cam bearings.
45 and 48 degree lifter angles available (can be spread .100”)
Will clear 4.750” strokes when using external oil lines.
Has expanded water jackets for improved cooling with large bores.
Cross bolted mains in 1-4 positions.
Caps have dowels to prevent movement in high hp applications.
Stiffening webs in valley
Chrysler and GM bellhousing bolt patterns
Only weighs 142 pounds.
