Does anyone use a fender mounted oil filter on the dart, I'm changing the motor and looking a the placement of the oil filter looks like a pain to change with the exhaust?
Are you running headers? If so and you use a short filter, it's not bad. I have been thinking about doing the same thing though when I replace my engine.
I do and it's great . Used some permacool fittings and had hydraulic lines made up. My lines are attached to the right angle adapter .
Changing the filter now is a breeze, no more oil on the headers.
Not the best pic, but I have had my filters relocated to the fender since 1983, wouldn't want it any other way, so much eaisier to change when doing an oil change. I have headers too btw.
And no I do not use Fram filters any more old pic.
Like this ?
I pulled all this stuff off the car for the new motor........now a Canton products filter plumbed into the front of the block with -10 from the filter boss..
So yes.......it's all for sale.
This is all I ever had on the car. So I'm not sure if its better than before. When I purchased the car right away I installed some TTI headers among a few other things. Do to the limit spacing from the headers I installed this. My motor is currently at the machine shop getting stroked, I may be ditching this and trying a short filter in the stock location.
