Fender Mounting Studs
charliec
richmond texas
Disclaimer First: I am definitely not a body man.
That out of the way, these are both studs that attached the lower part of the front fenders to the rocker panels (68 Dart). There are two such studs on each side of the car. First, I don't understand why they are studs instead of just a bolt...whatever. The short part of the stud uses a body bolt clip to attach to the body. Notice that the washer/nut is in a different position on these two studs. Assuming that the washer has to move in order to tighten against the fender once the stud is bottomed out, how do you move this washer?? It seems like it's in a fixed position and just rotates on the stud.
What's the problem with just eliminating the whole question and simply use a bolt instead?
Those are captive washer nuts, the washer is part of the nut.
There may have been some shims and that is why the nuts are in different positions or the nut spun on the stud a little more on one before taking the stud with it.
The stud probably made it easier to put shims in on the assembly line.
Alan
Put vice-grips across the 'shoulder' on the stud and wrench the nut off if you want.
Alan
