[Found!] Filler neck
After some research and talking to a fellow member on here, I need a 1970 filler neck.
Do you mean you want one with no vent tube in the trunk running along the filler tube?
I need a 1970 filler neck. They do have an tube attached to them.
The difference in the filler necks between vented and non vented is the depth of the tab that goes back into the opening. The shallow depth tab is for non vented caps. The deep tab is for vented caps.
What year filler neck do you have?
