moparmat2000
Finally got a bit of garage time. Started on my front lower radiator crossmember upgrade. I took some ideas from Rapoms Rocket resto thread on this one. I used 2×3 boxed steel. 1/16" wall thickness. In Rapoms build thread the 2×3 fit neatly over the rails on his duster. The cudas rails must be wider than the duster, or the tubing Rapom chose was 2x3 inside diameter, mine is 2x3 outside diameter as my tubing would not do this. I will make lap plates to tie it in. The tubing is Roughly same thickness as the original crossmember but boxed should make it a lot stronger. I taped a couple bondo spreaders to the bottom of the radiator to get the gap between the lower tank and crossbar for the initial tack welding. I still have to finish out the right side. The left side i cut out the arcs and rolled the metal over and welded it to get the nice curved corner. I still have to make landings to tie in the lower radiator mounts, and make a bracket for the hood release support bracket that bolts in the middle.
Thanks 4 looking
Matt
Thanks 4 looking
Matt
