finally got the holly 1920 off..need new carb?
cricket73
Active Member
louisville ky
ok, so after a hand injury halted my restoring the ol' dart, i'm back at it. rebuilt the power steering pump, and then got the carb off.. well, she's a mess. one item that is broken is the plastic power valve lever. is there a replacement? a quick search finds nothing online, and i kinda figure they're just not available. should i go with a new carb? if so, does anyone have a recommendation on where to buy from?
Might do better with the Carter BBS. I had bad luck with many Holley 1920's. I don't know about the Holley 1945.
If you decide to fix the 1920, post a photo of the broken part(s). I have many used parts for those.
I had a broken piece on my power valve too. I replaced it with another one from a donor carb. It ran much better after I fixed it. The plastic gets old and breaks. Too bad there aren't new ones in the rebuild kits.
