johnnyusa
I have been putting this off for years. I always keep a drip pan under my S6 because oil seeps from below the oil pump. I can't park in friend's driveways. I don't see a visible gasket between the pump and engine block but there must have been. I thought it might possibly also be beneath the distributor so I got a small gasket for that plus all gaskets for the oil pump. That should be enough.
Lifting the engine by following the MOPAR service manual says to drain stuff, remove mounts, remove throttle linkage, lift engine right front (passenger?) corner on jack stand, raise engine enough to put 8" of 2x4 between K frame and oil pan flange. Using pry bar, shift engine up and left to let 2x4 slide down to allow access to pump. They make it sound so simple but I know it's going to be some putzing. Has anyone tried this? Is there an easier way without removing the engine from the bay?
I'm attacking this 3/11/26 so any helpful advice would be welcome. Thx
