Finally pulled trigger on a front disc conversion
Brakes for your Classic Mopar
  1. Divenut
    Divenut Well-Known Member
    2,690
    785
    Sep 22, 2011
    Naperville Illinois
    Local Time:
    9:52 PM
    Well, after our last spirited drive, "The Boss" told me the car is running better than ever, and I had to "get some f'ing brakes on this thing!" So, obviously I had no choice but to heed her command.
    Been eyeballing this Wilwood 11023 kit for awhile and finally pulled the trigger. Will be running new lines front to back, new master cylinder and rebuild rear drums.
    Cleaned the garage and got the car in the air, plan on digging into the project after Christmas. I'll post pics and details as things progress.
    Be well and happy holidays everyone!
    • Like Like x 9
    • Agree Agree x 1
    • 6pk2goDemon
      6pk2goDemon Mopar Mod Staff Member FABO Gold Member
      11,506
      2470
      Mar 1, 2008
      Arizona
      Local Time:
      8:52 PM
      The Boss is obviously looking out for you....Congrats on the upgrade & looking forward to your progress with the install :thumbsup:
      • Thanks! Thanks! x 1
      • harrisonm
        harrisonm Well-Known Member
        1,897
        1180
        Jan 16, 2005
        Topeka, KS
        Local Time:
        3:52 AM
        You will LOVE the improvement. I think it is the best money I ever spent on my car.
        • Agree Agree x 2
        • stroked340
          stroked340 Well-Known Member
          4,886
          1140
          Jun 14, 2014
          mass.
          Local Time:
          10:52 PM
          Did the same swap on my duster a few years ago..like mentioned some of the "BEST" money I ever spent..:thumbsup::thumbsup:
          • stroked340
            4,886
            1140
            Jun 14, 2014
            mass.
            Local Time:
            10:52 PM
            Justed looked..and thats the same kit I have you'll love it.very easy to install no need to change any control arms or any of that other crap like with stock upgrades..did you upgrade the master cylinder and proportioning valve too??..
            • 72Dart6pack
              72Dart6pack Harder Better Faster Stronger.
              2,793
              1825
              Feb 1, 2016
              Roseville Michigan
              Local Time:
              10:52 PM
              The stock stuff from Doctor Diff is good too.
              :thumbsup:
              • Agree Agree x 2
              • Divenut
                2,690
                785
                Sep 22, 2011
                Naperville Illinois
                Local Time:
                9:52 PM
                Hey stroked 340, yes, I'll be upgrading both. And glad to here it should be a straight forward swap!
                Pat
              • Divenut
                2,690
                785
                Sep 22, 2011
                Naperville Illinois
                Local Time:
                9:52 PM
                Hey folks,
                Starting to dig into the project. Thanks to some input from fellow FABO members I was able to procure most of the necessary components for the job. Pulled off the front drums, de-greased and took off the rust from the Spindles, CA's etc. Then hit them with a few coats of POR15. Nothing show quality here, just protecting parts.
                20181229_114707_resized.jpg 20181229_123625_resized.jpg 20181229_140415.jpg 20181230_130740.jpg
                20190105_152212_resized.jpgView attachment 1715276439
              • Divenut
                2,690
                785
                Sep 22, 2011
                Naperville Illinois
                Local Time:
                9:52 PM
                Gonna remove the old MC and Brake Lines front to back this weekend. And start bolting on the Front Disc kit. Will update with more pics and trials/tribulations and things progress.
                Be well,
                Pat
              • Divenut
                2,690
                785
                Sep 22, 2011
                Naperville Illinois
                Local Time:
                9:52 PM
                Hey Folks,
                Got the adapter brackets mounted onto the drum spindles today. Other than drilling out a threaded bolt hole to 1/2 inch (pointing to in in pic 1) and using a floor jack to load the suspension in order to line up the holes for the steering linkage, no fuss no muss.
              • Divenut
                2,690
                785
                Sep 22, 2011
                Naperville Illinois
                Local Time:
                9:52 PM
                Pics...
                Drill out with 1/2" bit
                Use floor jack to line up holes for steering linkage
                Studs in hubs
                Used the rim to hold the hubs in place so I could get the 70lbs torque required.
              • Divenut
                2,690
                785
                Sep 22, 2011
                Naperville Illinois
                Local Time:
                9:52 PM
                Assembled the hub/rotor assemblies .
                Packed the bearings and pressed in the seals.
                Assembled hub
                Assembly on the spindle.
                I must say, this has been one of the simplest, straightforward mods I've done so far. My first impressions are very favorable !
                • Like Like x 1
                • Agree Agree x 1
                • Divenut
                  2,690
                  785
                  Sep 22, 2011
                  Naperville Illinois
                  Local Time:
                  9:52 PM
                  I'll be mounting the calipers later this week. Pics to follow as the project progresses.
                  Be well folks,
                  Pat
                • inertia
                  inertia Well-Known Member
                  3,093
                  436
                  Feb 4, 2011
                  Victoria B.C. Canada
                  Local Time:
                  7:52 PM
                  I hope it stays simple .
                  I'm interested to see if your wheels fit on when the calipers are mounted .
                  Good job.
                  • Divenut
                    2,690
                    785
                    Sep 22, 2011
                    Naperville Illinois
                    Local Time:
                    9:52 PM
                    Me too! I'm guessing the 15" Centerlines will clear everything, but keeping my fingers crossed. I'll find out in a day or two. Will posted up the results.
                    • Like Like x 1
                    • stroked340
                      4,886
                      1140
                      Jun 14, 2014
                      mass.
                      Local Time:
                      10:52 PM
                      My 15x3 1/2 Centerlines fit just fine:thumbsup::thumbsup:
                      • Divenut
                        2,690
                        785
                        Sep 22, 2011
                        Naperville Illinois
                        Local Time:
                        9:52 PM
                        Thanks man. While I guessed they'd clear, it's always comforting to get 1st hand, real world, feedback. That's what I wanted to hear!
                        Pat
                      • inertia
                        3,093
                        436
                        Feb 4, 2011
                        Local Time:
                        7:52 PM
                        That's not too comforting having the "1st hand dude" that swears his Centerline's fit fine, - deletes his post.
                        Who was that guy ? . lol
                        Fingers crossed.
                        • Like Like x 1
                        • Divenut
                          2,690
                          785
                          Sep 22, 2011
                          Naperville Illinois
                          Local Time:
                          9:52 PM
                          LOL... Just some dude, probably not even into Mopars, let alone A-Bodies. ;)
                        • Demonracer
                          Demonracer 71 Demon 00 Ram 16 Chrysler 300S 05 Caravan FABO Gold Member
                          2,065
                          241
                          Jan 31, 2010
                          Cleveland, Texas
                          Local Time:
                          9:52 PM
                          You'll enjoy the braking difference with the Wilwood disc brakes, I have Wilwood manual discs on all four corners of my bracket car & the braking is excellent. Your Centerlines should fit with no problems, I've had those & Prostars on my car with no fitment issues.
                          • 72Dart6pack
                            2,793
                            1825
                            Feb 1, 2016
                            Roseville Michigan
                            Local Time:
                            10:52 PM
                            And if they don't fit? Then what?
                          • Divenut
                            2,690
                            785
                            Sep 22, 2011
                            Naperville Illinois
                            Local Time:
                            9:52 PM
                            Then I sell the Centerlines and find different rims that fit.
                            Pat
                            • Agree Agree x 1
                            • Divenut
                              2,690
                              785
                              Sep 22, 2011
                              Naperville Illinois
                              Local Time:
                              9:52 PM
                              Hey folks, just another quick update. Got the hub assemblies torqued to spec and loctited. Froze my a$$ off in the garage but got the calipers mounted. Test fit the Centerlines which fit with room to spare. The hardest thing of the whole installation was torquing the Torx head bolts to spec. Two trips the the store and 4 trashed T40 bits later, I got it done. LOL!
                              Will do the master cylinder swap later this week.
                              Be well folks,
                              Pat
                            • inertia
                              3,093
                              436
                              Feb 4, 2011
                              Local Time:
                              7:52 PM
                              Thanks very much for reporting back.
                              Looks great.
                              Good job.
                              • Divenut
                                2,690
                                785
                                Sep 22, 2011
                                Naperville Illinois
                                Local Time:
                                9:52 PM
                                Ya, I guess the old MC has seen better days. The new MC and Brake Lines are definitely long overdue!
