firewall clutch rod location on 71 dodge demon?
Tom Derych
New Member
Arizona
Where is the clutch rod location on a Dodge 71 demon? Firewall has been completely modified and I do not know exactly where the hole would be.
Does anyone have pictures of the firewall with clutch rod in place from inside the car?
Here is a pic of my car on a rotisserie, the hole is to the right of the large hole for the steering column...
Couple from mine, one from the inside and one from the outside. In the engine compartment picture it’s backlit, from the inside it has the oval plug in it. Sits just left of the steering column opening, just below the brake like retaining tab on the firewall. There’s a few other indents in the pictures you should be able to use as landmarks.
An FYI all 67/ later A bodies are in essentially the same place
