Mar 27, 2016 #1 R ronw Well-Known Member Joined Dec 29, 2011 Messages 197 Reaction score 12 Location cashtown,Pa. need some ideas on how to run my wiring from my gauges through the firewall that is safe from being cut and water proof.Thanks Ron
Mar 27, 2016 #2 Matts440 Well-Known Member Joined Apr 11, 2014 Messages 3,443 Reaction score 2,126 Location Nampa, Idaho Can use a grommet and some plastic covering and just tape the covering to the grommet or there might be boot you can thread all the wires through like this from Summit racing Attachments DYS-KU20040BK.jpg DYS-KU20040BK.jpg 7.4 KB · Views: 166
Mar 27, 2016 #3 Matts440 Well-Known Member Joined Apr 11, 2014 Messages 3,443 Reaction score 2,126 Location Nampa, Idaho It's called daystar firewall boot
Mar 27, 2016 #4 toplscuda Well-Known Member Joined Jan 23, 2005 Messages 2,928 Reaction score 6,299 Location St. Louis This is another alternative if you want a completely sealed and easily disconnected setup. Look at the bulkhead connectors http://m.delcity.net/store/Weather-Pack-Wire-Connectors-&-Components/p_797633
Mar 27, 2016 #5 Matts440 Well-Known Member Joined Apr 11, 2014 Messages 3,443 Reaction score 2,126 Location Nampa, Idaho Thats a cool one ^^^
Mar 28, 2016 #6 SBeeMan Well-Known Member Joined Jan 19, 2013 Messages 212 Reaction score 54 Location Crossnore NC I used these alot for wiring,fuel lines & even roll cage seals,work great http://www.sealsit.com/grommet-seals.html
