Map63Vette
So I finally got the 5.7 all in and ready to start trying to get it running, but I ran into some issues tonight when I was first cranking it over. I filled the oil pump from the external fitting and rotated the engine backwards as suggested elsewhere in these forums, and it pulled the oil down the tube fine, but when I went to crank the engine over I'm still not getting any oil pressure. I have a mechanical gauge hooked up and an idiot light and I'm not even getting the light to go off. Secondly, I'm going with a carb setup and an MSD box to control the timing, but I don't think I'm getting any spark. The engine doesn't even really sound like it's trying. Is there any easy way to verify spark on the 06 style coils? I watched the MSD program while cranking and nothing seems to be changing. I don't see any RPM and the only thing it ever said was a "Cam Sensor Error". It only threw the error twice in probably 5 times worth of cranking though, so I didn't know if this was just a hiccup that happened during cranking or the main issue. I plan to try a new cam sensor tomorrow to see, but pending that, anyone have any ideas or suggestions as to what might be the problem? The oil pressure thing really bothers me, but I was hoping with enough RPM it might prime since cranking doesn't seem to be enough.
