Hey guys I know we all love resurrected threads (har har)... Today I went to the drag strip again with a pretty different drivetrain combo and had some interesting results. Before I had skinny bald BFG banana skins with that stock rear end, now I have an 8 3/4 with 4.10 gears and sure-grip I borrowed from FABO member "nothingbutdarts" and 275/60-15 Firestone Firehawk Indy 500's on the back. I also replaced the mystery higher-stall TC with a stock unit which actually didn't improve the gas mileage like I had hoped but whatever...
About a month ago I made a couple runs with REALLY bad tire spin and could only muster a 15.8 @ 88 which annoyed me, that was worse than with the 2.76 gears and skinny tires! But today after I threw a 150-lb old tire filled with sand in my trunk and airing down the rear tires to 15 psi I was able to run a best of 14.9 @ 94 MPH. My main issue this time was with the carb, my old AFB got bad heat-soak and would lean out and bog halfway down the track until I sprayed the engine down good with some water. So next step for sure is tracking down a 750 cfm double-pumper, also want to cut a hole in the hood for a proper scoop and seal the air cleaner to it. After that I'm thinking of getting some good drag radials that are a bit shorter, and finally a bigger cam to move the torque curve up the RPM band.
EDIT: Also forgot to mention I weighed my car at the track and with me (150 lbs), that tire weight (another 150 lbs.), about 1/3 tank of gas and a bunch of random tools and shite in the trunk (maybe 80 lbs?) it was 3660 lbs. Does this sound about right? Where can I look to remove weight but not off the back end of course?
