FiTech 1200 PA system added
Forced Induction Mopar
  1. Coyote Jack
    Coyote Jack Member #55, I'm old FABO Gold Member
    8,326
    1944
    May 22, 2004
    Baxters Corner N.B. Canad
    Local Time:
    3:43 PM
    I finally managed to get my 1200 PA system up and running. I was delayed for a while due to a hip replacement. After a few growing pains I am real pleased with how it works. I now have about 30 miles on it and it has worked without a hiccup for the most part. Much better than the twin 600 Holleys I had. My biggest problem was I had my linkages moving to fast and it made it very touchy to drive. I slowed down the opening rate by adjusting the linkages and now it is a joy to drive. My setup is a 72 Demon, 340 with a 6-71 blower. I am controlling my timing with the MSD 6AL for now. I may use the timing control of the 1200 PA after I get used to it. I used an inline Walbro 392 fuel pump and it seems to do the trick, I ran a return line back to the top of the tank. I still have to learn how to tune it but for now I am real happy.
    Jack
    • Like Like x 9
    • Darticon
      Darticon Well-Known Member
      124
      45
      Aug 29, 2014
      Missoula, MT
      Local Time:
      12:43 PM
      I more than just "Like" this but there is no higher rating... That looks like some serious fun there.
      • Agree Agree x 2
      • Like Like x 1
      • Thanks! Thanks! x 1
      • famous bob
        famous bob mopar misfit
        11,238
        2784
        Aug 14, 2011
        okla
        Local Time:
        1:43 PM
        kICK A$$ CAR. Return lines should be in the gas level, to avoid aeration. May or may not plague u tho.
        • Coyote Jack
          8,326
          1944
          May 22, 2004
          Local Time:
          3:43 PM
          No problem yet Bob. Fingers crossed.
          Jack
        • canadian duster
          canadian duster Well-Known Member
          132
          12
          Oct 29, 2015
          lloydminster alberta
          Local Time:
          1:43 PM
          Love it. I'm glad it's working out since I'm hoping to fire the same system up this fall. What size of fuel line for supply and return did you go with? You were running a meth injection for a time correct?
        • Coyote Jack
          8,326
          1944
          May 22, 2004
          Local Time:
          3:43 PM
          I use a 3/8 ths fuel line and return. Seems to work fine but I don't race it so I am never at WOT for to long. I do have Meth injection but I only have it hooked up when I put the go fast pulleys on that give me 10+ lbs of boost. My usual boost is 6 to 7 lbs. I am going to learn more about tuning this EFI before I get into the meth injection again.
          Jack
