dodge71demon
For those of you using the Fitech or Sniper EFI are you controlling the timing through the system if so why and how often is it necessary to use that feature on a fun daily driver with no added booster
id like to know too.For those of you using the Fitech or Sniper EFI are you controlling the timing through the system if so why and how often is it necessary to use that feature on a fun daily driver with no added booster
that's the one im looking atI haven't tried it yet but I plan to. Still ironing out the kinks. I am using the Fitech power adder 600 HP kit.
I am still getting the kinks sorted out. Although they say that its "self learning" it's only partially true. I still have cold start issues where I have to hold the throttle down to get it to start along with a bit of issue with it feeling like the fuel is cut off when I lift the throttle (l think that it's getting confused because my manual valve body coasts in third gear when I let off of the throttle). These things are minor and I have no doubt that I can iron them out, it's just finding the time (I have a field service job and I am typically out of town 5 days a week and when I get home there's always a bunch of things that need worked on, this week it was the furnace). Anyway you look at it you will need a proper fuel injection fuel system. I went with a Tanks Inc fuel tank and I also bought the pump and sending unit from them. I bought the braided steel lines and AN fittings from Summit. All this and a few miscellaneous items will cost you about another $600.00. if I can help in any way please feel free to PM me. If you would like I can give you my phone number then.that's the one im looking at
