[SOLD] FiTECH GO STREET 400hp
David W
Santa Clara ca ..
Complete set up with 2 fuel pumps and all fittings
Ran it on the car ( Slant 6 ) for 20miles and took it off..
Info here Go Street EFI + In-line Fuel Pump Master Kit
PRICE DROP
$825 shipped ....
here a bit more info on what in the pics ..
1. Im missing the return line bung ...but im sending you a few gas tank bungs and the AN fitting for them. If you want to pull fuel out of the bottom of the tank..
2. you get two temp sensors - the one it comes with and a LS gen 3 temp sensor
I used the Gen 3 its smaller..
3. In the baggies .. O2 sensor / parts and fitting / main wiring /
4. I have about 22 feet of injection hose that can come with it ...but that would mean you cover the shipping for it ..
Sorry guys .. here a link to the pics ...
Photobucket
I was looking for an efi unit for a /6. Your unit work?
it will if you have some work done on the motor.....
there's a few guys on there's a few guys on the slantsix.org that run them but for me I couldn't get it to dial into where I liked it on my stock motor....
I have a question. On the FI tech website it says something like “this system strays away from programmable features and focuses on the basic functions to make it run...
Not sure what that means exactly. Sounds like you can’t hook up the handheld programmer and make
changes, but is this system still self learning?
it is self learning .. you can program a bit threw the controller ... but what they mean it not so nut and bolt that you need laptop just to get it up and running ... but you can pull your tune and put the SD car n to your laptop and twerk you set up ...it a great part and works well for 80% of the people that will use it ...
