Fitted the gas tank seal and took the Dart for a "test run" :)
1966DartConvertible
Malaysia
Lovely Sunday morning drive up a very steep hilly drive... nice view too! Here are some pictures:
Yeah I know the Visor need to be fixed...
And here is "yours truly" at the wheel... top down of coz...
And here parked at a coffee shop (I love this "retro" setup with the old bicycle)
and here parked by the riverside
Hope you had a as good a weekend as I did.
Cheers
Syed
The vents are purdy :) Please show them again installed. Happy moparing
the gas tank seal is that the one where the filler tube goes into the tank. I have to change mine as well any tips? was it hard to do?
Thanks
Bill
1965 Dodge Dart 270 convertible....
Thanks
Bill
Yeah that's the seal.
Well, I know im gonna get screwed for not doing the "correct" way, but...
The old seal on mine was literally cut in half. So when I removed the old filler neck the seal came out together. Then before installation, I lubricated the ID and OD of the new seal with rubber grease (ATF will do fine) and put it back in. I didn't have to drop the tank... (will do that once I have more time to remove the black paint). Oh, I have small "Asian" hands, so I can squeeze the new seal in through the hole in the trunk where the filler neck goes in without any problem.
Hope this helps.
Syed
