Fixing dim/blinking headlights
tenn73duster
New Member
There is a fix to dimming or blinking headlights in August 2008 mopar muscle that gives a schematic on how to fix the problem using a relay I am pretty good with wiring but I can't figure out the blue wire coming from the bulkhead to the starter relay. If anyone has that issue, or the knowledge help me out.:munky2:
The article says that the blue wire originally went to the voltage regulator in the bottom schematic(via bulkhead). Remove that wire from the regulator and connect to the coil side of the relay that is not grounded in the second schematic. The blue wire is used to turn on the relay and supply voltage to the alternator field to energize the alternator. Good Luck
THIS IS CORRECT, BUT THERE IS ANOTHER BLUE WIRE THAT IT SHOWS COMING OUT OF THE BULKHEAD GOING TO THE STARTER RELAY THAT I AM NOT SURE OF.
THANKS
I used the two wires that originally fed the head lights to activate the two relays (one for hi one for low) added power and good ground wires. I hid everything under the battery.
