Fixing Grille Tabs with A 3D Printer
ro23dart
Harrisonburg
I finally got my 71 Dart grille off my donor car and aside from needing paint and one broken tab it was in good shape. I decided to try to fix the tab using a 3d printed piece and see how it goes. Below is the story with some pictures just in case it may help someone in the future.
First off i copied the tab from the other side and designed a piece to slide on to the existing bracket where it was broken. It looked like just the bottom part broke off so i added slot to give the part some more material to adhere to. Below is the test piece that i printed in PLA.
I did a dry test fit and everything looked good.
Next step was to print it out in ABS. Printing ABS can be a pain in the butt and it took me a few tries to keep it from warping too much. I ended up with a couple of junk pieces so i used them to test plastic welding with ABS and acetone.
Everything seemed to bond pretty well, i used a brush to brush on the mixture and a carving tool to spread the thicker slurry. After curing for a few days it seems pretty darn solid so i think it was time to try it on the grille.
After letting it dry for a couple days it seems to be very solid. I didn't use the carving tool to spread it on this time, instead i brushed the inside of the tab and the outside of the strut and then stuck them together and brushed on more along all the seams.
Looks good, if you take some orders and make them longer where attach you could make some cash, I'm sure they are needed.
