RobertP
recently installed a new flaming river tilt steering column. Went to turn the key from the on position to the start position and immediately the steering sector shaft gear, which is plastic clicked one tooth and would not turn back to the off position. upon taking it out and resetting it, as well as verifying that with the rod itself it will go to the start position no problem. reinstalled and yet again same result. removed and reset this time adding a starter button and turning the to on position the car will start no problem. anytime i turn it past the on position it pops and i have to remove it and reset it. Has anyone else had any had any experience with these steering columns and this terrible GM design? calling Flaming river in the morning just looking for some insight?
