71DartGuy
Is it possible to use the stock roller lifters with a hydraulic flat tappet cam. The reason i ask is I am using a magnum block and the roller cams that comp makes are either a little too tame or will require machining down the valve guides for clearance. The flat tappets are about $175 cheaper too. I guess it wouldnt be the end of the world to go with regular hydraulic lifters if they will work with the taller lifter bores???
Thanks for the help in advance
