[SOLD] Floor console, shifter, brackets and linkage
drp2671
Olivehurst, CA
Here we have some more floor console shifter items for sale. You can obviously see that the console needs the wood grain sticker replaced. It could use a good cleaning for certain. The chrome is in "ok" shape, has some pitting. The console door is a little warped as it does not sit flush on the back end of it. Not pictured is the rest of the shift linkage, i.e. Torque shaft, torque shaft bracket(bolts to the bottom of the transmission) and the rod that goes between that to the shift lever on the tranny. $250 plus shipping.
I'll give it a few days if it doesn't sell as a package then I'll take offers on the individual parts.
Thanks!
Interested in the bottom shift bracket (that bolts to the trans), and the lower shift rod (from torque shaft to trans shift lever) , if you have it and decide to break up the set.
Thanks.
Thanks.
65Val,
If it doesn't sell as a package deal in a couple days, you are first in line for those two pieces.
Thanks.
If you still need that bracket I have one for the 904 Trans. The are different from 904 to 727. PM me if you need it. Thanks
I would like the shift knob and the long weld on bracket for the floor (goes under the console door). Thank you
