I have a Blueprint Engines magnum 360 stroker with an Airgap RPM intake. The intake has the water pump fitting sticking straight out (OE small block has the fitting at an angle). The Flowkooler model 1700 that I have has the fitting going to the intake at an angle. I made the bypass hose fit but it is not correct. Flowkooler makes a magnum water pump for the magnum engine but it is different that what I have (spins CCW and mine goes CW).
I need a high flow WP to deal with the Texas heat! Ideas?
