pastortom1
On a new 273 rebuild (.30 over, very mild cam), the motor came back with a slight imbalance..... It COULD be that they used a new converter on my 904 with a counterweight....I have NOT verified this yet, but will shortly.....
My question is this: If the converter is neutral, and they used the stock balancer (also neutral), will a "Fluid-Dampr" take care of any remaining vibration due to a slight imbalance problem? (the vibration is evident at 'idle'....this is not a tranny to rear problem).
