rklein383 said:I read in a Street Rodder magazine that the polarity of the welder had to be changed if you went from solid wire w/ gas to flux wire. They even showed a picture how to do it. All I know is when I put flux wire in my mig welder, I couldn't weld worth beans.
Rod
dgc333 said:I signed up for an adult education class in welding where I got to use solid core wire with a sheilding gas. What a difference, by the end of the 10 week class I could butt weld 22 gauge steel with ease.
Brambles said:I'm using .023 and CO2/Argon mix, power set on 1 and wire speed at 10 and I have a hell of a time trying not to blow holes. Tacking is no problem but if I try and buttweld any longer than 1/2 inch or so then she blows through. Welder is a Hobart 135. Sure wish I could butt weld 22 guage. How long are your welds and are you using a heat sink on the back side?
Might try and speed up the wire feed to see if that cools the arc down.
