Flywheel Help Needed....will a 143 Tooth Aluminum Flywheel work on my 340?
66340SEDAN
FABO Member #3649
Minnesota
I have a vintage NOS Sheifer Aluminum 10 1/2" 143 tooth flywheel (think its for a 68-69 Body BB), I was wondering if this would work on my 340? I have a 10 1/2" stock steel flywheel now but not sure how many teeth are on the SB one, mine is from 1972 I believe. Would the different teeth count make the difference? Both flywheels are internally balanced too.....Thanks alot! :glasses7:
I know you said 10.5" and 143... but 10.5" is 130 and 11" is 143. You will also need to worry about the Bell Housing (will a 11" fit) and is it a 6 or 8 bolt flywheel (does it match your crank). And lastly your clutch...which I'm sure you already knew would need to be changed.
You can't put a 143 tooth wheel into a bell housing for a 130 tooth wheel, it wont fit.
Ok, here are some pics
Chrysler, Dodge and Plymouth
30-30069 / 70-71 440 (10 1/2" Beck & Borg Plate) 130Tooth
30-30067 / 67-69 440 & 68-69 Roadrunner (10 1/2" Beck & Borg Plate) 143 Tooth
3362L / 62-64 Chrysler 6 Bolt crank w/starter adapter (11" Long Plate)
3362 / 62-64 Chrysler 6 Bolt crank w/starter adapter (11" Beck & Borg Plate)
30-30066 / 66-69 426 Steet Hemi (8 Bolt Crank) (10/11" Beck & Borg Plate) 172 tooth
310A
Mine is the 30-30067...must be BB only...
310A
Interesting...but as you said, must be big block only because of 143 tooth ring gear. The physical size of the ring gear will be your limiting factor. Not sure if aftermarket SB bell housings accept a larger 143. Or if it is even possible because the location of the starter would changed based on larger ring gear (interfere with exhaust or clutch linkage?).
Do you happen to know how many teeth a SB one has? I forgot LOL :glasses7:
I think it might be 130 for a SB?
Looks like that aluminum one is drilled for external balance, the other is not, unless it's on the other side.
