If this goes 14.30's, I'll send a gift card for you to go out and eat !!!!!!!! LOL It's going to be fun regardlessIm gonna say 14.30 just because I know the tuner!![]()
I don't, it has the 5.5x5 bolt pattern. She'll have to grunt some... LOL17.05 at 79.95 mph...got any 27" rear tires to put on the beast?
I'll give you my thought process behind it. I know your 3200 lb duster when low 13s with a low compression 360 and a open 245 gear (somewhere around there) the van if memory recalls has a sure grip with lower gears. And I know that 5.9 is probably hotter or just as hot as the low compression 360 in the duster. The van is not as heavy as you might think. Im guessing 4200lb. So 1 tenth per 100 pounds that's 1 sec. Take a few tens for the lower gears and possibly stouter magnum I end up at around 14.5 but you driving is worth 2 tenths so I ended up at 14.3 lol good luck I hope im rightIf this goes 14.30's, I'll send a gift card for you to go out and eat !!!!!!!! LOL It's going to be fun regardless
I like the thought process.I'll give you my thought process behind it. I know your 3200 lb duster when low 13s with a low compression 360 and a open 245 gear (somewhere around there) the van if memory recalls has a sure grip with lower gears. And I know that 5.9 is probably hotter or just as hot as the low compression 360 in the duster. The van is not as heavy as you might think. Im guessing 4200lb. So 1 tenth per 100 pounds that's 1 sec. Take a few tens for the lower gears and possibly stouter magnum I end up at around 14.5 but you driving is worth 2 tenths so I ended up at 14.3 lol good luck I hope im right
It will probably never hit the track again after Saturday. It will have one shot at a "personal best" LOLI'm going to say slow.....really freakn slow...although it is suppose to be cool Saturday (first race day for me as well), so whatever you get, it will probably be a personal best for it, lol. Good luck.
For grins and giggles....17.84
8.25 with a 727. I was surprised the B250 would have a 8.25 in it. It is a sure grip.So that has a 9-1/4 under the rear. Does that have a 727 or a 518 in it?
Then it's not a 3/4 ton van8.25 with a 727. I was surprised the B250 would have a 8.25 in it. It is a sure grip.
20.9 I knocked off a few tenths. lol21.7 and a slow MPH.that ain't no Duster
It's a B250, whatever that means. LOLThen it's not a 3/4 ton van
I really like a challenge.... LOL You know if I go 19.88 I'm removing the pillow19.90.
That way if I'm right, I can claim to outrun you heads up in my 19.87 Mighty Valiant!![]()
I plan on wearing the linebackers neck brace20.9 I knocked off a few tenths. lol
Is the van equipped with the Hans device, I wouldn't want you to snap your neck.
I'm pretty sure the 250 is 3/4 ton designationIt's a B250, whatever that means. LOL
