ir3333
..how many amps does a horn draw?
..thinking of wiring one directly to a push button through an appropriate fuse
15-20 amps usually does it, but put a 30 if it tickles ur fancy.lol
Seems like a good way to turn your harness into a fuse to me. Since the original poster doesn't state the amperage draw on his horn the fuse size can only be guessed at. Is it a replacement roadrunner horn or is it a jc whitney made in china knockoff? They will have different amperage draws. I would still run it off of properly fused relay regardless of method of trigger.
Cool, lets assume the worst case scenario..lol
Though a relay is the way to go and have one in my '67...Read the second post by slantsixdan in this thread and then you will know why I posted what I did.
http://www.slantsix.org/forum/viewtopic.php?p=138145&highlight=#138145
Well think what you want about Dan, but he won't steer you wrong. .
then 67Dart273 shocks us all with the breaking news that he doesn't like me,
For the electrical gurus excepting Dan I quess.
Well think what you want about Dan, but he won't steer you wrong. By asking this question very question you are exhibiting a deficiency in automotive DC wiring methods. Wire up the horn anyway you want, its your car.
My 2 cents for anyone reading this thread:
Wiring a push button direct between battery and horn will result in a melted push button.
The problem is most push buttons are not rated for much amperage, cannot provide positive tight contact sufficient to keep switch closed without arcing. You have to employ a relay in the circuit to handle the high current draw that a horn requires which can be safely triggered by a push button switch.
