Princess Valiant
A.K.A. Rainy Day Auto
I have an 88 f250 brick nose and I bought it with the smog pump disabled, the serpentine was changed to avoid the smog pump.
So now I'm changing it to a quick ratio manual steering so I need to delete the power steering pump and bracket which also has the tensioner.
Can I convert a serpentine setup to an older style fan belt because all I need is the altenanator and water pump, that's it. Truck does not have a/c compressor.
Not sure how to clean this up.
