Good idea. I'm thinking it was a Mustang because the guy I got it from was a mustang guy and he got it when he bought some other guys pile of mustang parts. I'll look tonight. These things are inexpensive. I've seen them as low as $125 or as high as $300. But this is the only one I've found with 1:3.00 gearing.
Actually, that's 3.00:1. The drive shaft (pinion gear) number comes first. The "1" refers to the axle turning over one time. SO, that means drive shaft turns 3 times, rear axle turn once, so it's a 3:1 ratio. Decent gear for cruising. Ford did that a lot. 3:1, 4:1, and 5:1. Most Ford guys say "300 gear", "400 gear" and so on. Most other makes went 3.23, 4.10 but Ford rounded some of their gears off even like that.
