found 340
1B, so you may be looking for a Demon, Duster, Challenger or Cuda.
Is that a build date or casting date?
I have a block that cast 7-1-70 but a
build date of May-6-71, Vin 1B391***
Your cast date is even further out, your cast date on the block is before his but your build is after. I would think his build date would be march or april.
My block was .020 from the factory so I think it got set aside and fixed at a later date, then put in a car.
In front under the left head, it's a julian date code so it would have to be looked up on a calculator, just list all the # on the front
heres what I got it looks like GM 340P 35680008
Final assembly day - May 5, 1971, 8th engine completed at the same plant this day.
