Found Broadcast Sheet 1969 Dart H code
jayson
If this belongs to you send me a PM with a picture of the vin and car also your address and I will mail it to you.
Wouldn't an h code by definition be a GTS?
Go on GTS registry and contact them they might have info
Interesting information, thanks for posting. What I found is the H in the fifth digit in the VIN for the 1969 model year is for a 383 HP car. P is for a 340 car. Thanks.
H-code is a 340 in 69 and would be a GTS...
I'm not sure where this misinformation sheet is from, but not only is it incorrect for the P code for 68/69 340s, it was also recently incorrectly used to assert the G (not F) code was used to indicate the availability of a 318 poly in 1968. It also fails to indicate the use of M to represent special order V8s such as the 440-6 in 69 B bodies and 440 in 69 A bodies.
