[SOLD] Fresh 360
Dartn440
Southern Pines, NC
Up for sale Fresh motor.
Mild street 360. Jan 1979 date code block. Fresh heads stock 1.88/2.02 valves with fresh 3 angle grind. Surfaces milled for compression ratio of 9.5:1. New Sealed Power .040 H116CP pistons on balanced assembly with fresh bearings, seals, and plugs. New Edelbrock 600cfm carb with electric choke on an Edelbrock Performer 318/360 intake. New COMP cam, lifters, push rods, and springs with 1.5 roller rockers. Cam grind CRSXE274H-10. .488/.491 lift on 274/286 duration. New oil pain, pick up, and Melling HV oil pump. New Edelbrock valve covers and air cleaner. New alternator, distributor, wires, brackets. Built to be Paired with a rebuilt 904 transmission, 2200 stall converter and a B&M external balance flex plate. Ready to drop in to your Mopar street car! $5,500 without trans
Shipping, crate, and freight fees extra. Can have installed in your ride for extra.
Thank you. Mike built a couple since most times there is something being broken in, run, etc. I know he has sold before, but not sure what he asks. We have put some stress on a few of these and no issues. Just change out mounts and go between big and small block. Also nice to trouble-shoot everything and get a decent tune outside the car before install.
