That is not possible, unless the axles are to short, wrong spline. Since you say you changed the third member out twice.
Axles are 28 inch Yukon have ran the same rear for years , This was a driving rear end , Axles go all the way home splines correct etc ,
Just noticed you said you have Yukon axles. A few yrs. ago a buddy of mine put a set in his A-body 8-3/4 and they seemed to bottom out but in reality they were just barely long enough to engage in inner set of side gears (engaged only about 1/4"). The first time he took it out and jumped on it the splines stripped off the end of the axles and it would no longer pull itself. When the rearend was jacked up the tires would turn, but not when on the ground. The driveshaft turned all the time.
I think I'd pull the axles out and have a look at the splines
This doesn't make sense. The drive shaft CAN NOT turn if the car is sitting on the ground! Not without moving the car!
Not likely. If you can turn the driveshaft while the car is on the ground the problem is in the rear end.
Just one Thought maybe when the Block in the Pumpkin was Removed would the axle splines have past the side gears hence not meshing ?????
I think the op better investigate the rear axle. the last time my driveshaft turned and the car didn't move, I found a broken ring gear inside the housing
